Sunsynk better explanation Program charge/discharge then in the manual
I have a Sunsynk 5KW inverter and page 32 Installation manual  explains what you can set in system mode for Program charge/discharge times. Only it is so concise I can not grasp it.
So if you know loadshedding is at 1pm for 4,5 hours and the sky is covered with clouds from early morning I would like the grid in the morning to load the batteries. What setting in system mode should I do?
