Items needed for installation
Hi all
Can anyone guide me on what I would require besides the battery, inverter and panels. How many of each item and specs/watts. Also if you can recommend a place in Jhb that is priced well?
Below are the hardware
1x5kw luxpower SNA
2X5kw Greenrich WM batteries
8x 545w panels
Thank you
6 minutes ago, DeezGP said:
Hi all
1x5kw luxpower SNA
8x 545w panels
Thank you
In order to assist you will need to give a distance between panels and inverter.
Distance from DB to inverter.
9 minutes ago, DeezGP said:
Hi @Scorp007
Panel and inverter +-7mts
DB to inverter +- 7mts
Thanks for your time and assitance
Solarway suppliers
Let's kick off and other members can add as we go along. Bear in mind I am not an installer so will miss a lot of items.
10mx4mm red solar wire
10m x4mm black solar wire
3 lengths of 20mm PVC conduit
8 way DIN rail DC DB
2 or 4 PV DC fuse holders with fuses(1 or 2 strings)
2 or 4 SPD for panels (1 or 2 strings)
2 x 3 way switch type fuse holder + fuses for batteries
3m x 35sq mm red and black cable for batteries
1 x 1m 70sq mm red and black cable for inverter battery input
2 x 32A AC MCB for in and out supply to and from inverter
2 pole SPD for AC
40A transfer switch
Suitable labels
40x40 trunking to suit your layout
PVC glands to suit
Earth spike
+/- 20m x 10mm earth wire to spike
Got some customers to see me.
You'll also need the hardware and mounting rails for your solar panels- this depends on the location (roof, freestanding), the type of surface (tiles or roof sheeting) and whether you have a good angle already or need a frame to adjust the angle
