Solar Panel Comparison
This post was recognized by Energy-Jason!
Colind was awarded the badge 'Great Content' and 25 points.
Hello everyone.  For those of you like me who are looking to compare the various panel spec sheets, here is one i have put together from the data sheets for the panel manufacturers and size range that I am interested in.  Feel free to add to it if you have additional info.  THe sheet has info for Canadian Solar, JA Solar and Jinko Solar panels from 570 to 630 watts.
Solar Panel Comparison -Canadian-JA-Jinko.xlsx
Great stuff. Thank you.
Honestly, it more depends on your inverter and solar input.
I was goverened by single mppt, 500VOC and 18A, 5000w.
So I needed the strongest so that I could go less panels and keep within the reqs and get as close to 5000w.
8 x Jinko 620w brought me to 4960w, 13A and 444ish Voc. Good.
Other panels were lower VOC meaning I could go more, but Amp started bordering etc etc.
If I had dual Mppt my setup would have been different with lower Watt panels more in parallel.
If you get any of the top 5-7 rated you cant really go wrong. So add Sunpower, Qcells etc to that list. Those are all good panels as long as they arent bought in an alley.
Im sure that great list will help many! Thanks
Edited by Eurard
