June 2, 20233 yr Any other affordable HV batteries on the market, other than the Freedomwon,Fox ess,pylontec, and sunsynk/deye batteries? Need a battery of 200vdc+ for a 50kw sunsynk. Any suggestions to concider? Thanks
June 2, 20233 yr Author 7 minutes ago, Steve87 said: It's a Niche market, Bluenova, Solar MD also do them. SolarMD is a brand that havnt seen yet, ill check it out .thanks
June 2, 20233 yr 34 minutes ago, petrus.van said: Any suggestions to concider? Not sure about affordability in SA but check out Weco 5K3 XP dual voltage LV/HV modules that can be used in a Low Voltage(48.5-58.4Vdc) configuration or in a High Voltage(80/200-750Vdc) configuration.
