July 5, 20233 yr Author When the Main Power returns, the lights flicker, and the only way to clear the problem is to a total shutdown of the Inverter.
July 5, 20233 yr 13 minutes ago, Hannah said: When the Main Power returns, the lights flicker, and the only way to clear the problem is to a total shutdown of the Inverter. What inverter do you have installed?
July 6, 20233 yr Author Good morning,5KW Off-Grid / Grid Backup MPPT Solar Inverter with two 48-volt lithium iron 5.5 KW batteries UPS-INV-5KVA-5048TG Generation 2
