July 9, 20233 yr 9 minutes ago, Scorp007 said: I would have thought that Aberdere that have been manufacturing cables for decades is a trustworthy source to use. Indeed. For 100% duty cycle welding, you can use their 35mm² cable at 220A, exactly as the manufacturer says. But does the manufacturer give a rating for use as household wiring? Remember, welding cables do not form part of supply cabling, and have completely different design and testing standards (SANS 1574 for supply and SANS 1576 for welding). I have only found one manufacturer who actually rates their welding cable for supply wiring, and that rating is far lower than when used for welding: https://cableconnection.co.za/pvc-nitrile-welding-and-panelling-cable/
July 9, 20233 yr 1 hour ago, JustinSchoeman said: Indeed. For 100% duty cycle welding, you can use their 35mm² cable at 220A, exactly as the manufacturer says. But does the manufacturer give a rating for use as household wiring? Remember, welding cables do not form part of supply cabling, and have completely different design and testing standards (SANS 1574 for supply and SANS 1576 for welding). I have only found one manufacturer who actually rates their welding cable for supply wiring, and that rating is far lower than when used for welding: https://cableconnection.co.za/pvc-nitrile-welding-and-panelling-cable/ Not rated for wiring but I just wonder how many battery cables are not welding cable. Based on what I have seen when PV sellers cut battery cable I have only seen welding cable cut and easy to spot. Further not many battery systems are over 100V to earth AC or DC as per the SANS 1576 spec. Welding cable can also go to 85 deg instead of the normal 70 deg rating. Enough of hijacking the topic.
July 9, 20233 yr 7 hours ago, Scorp007 said: Not rated for wiring but I just wonder how many battery cables are not welding cable Fortunately, the SANS spec gives the leeway to use the ratings from section 6 if there is no appropriate manufacturer rating, so you can use welding cable - just need to stick to the appropriate current capacity from tables 6.2 or 6.9.
