Lithium battery? Mecer Inverter
Hi All,
I am sure this has most likely been asked before, but blonde me can’t seem to find previous threads on this topic.
I have a Mecer 12V inverter (720W). Would I be able to swop out the deep cycle battery with a lithium battery. I have seen some conflicting info regarding this and very unsure and weary to fork out lots of $$$ for a lithium with the risk of it not being compatible. Would so appreciate your insights. Many thanks.
15 hours ago, Nix said:
Hi All,
You are right. Some people have found the inverter will not switch on. If the lithium battery is connected to another inverter it works fine.
It remains a risk.
Further the lithium should not load to 100% as the charger voltage is a bit on the low side. They were designed for lead acid and also protected the lead acid by not charging to 100% SOC.
To make it worse there are friend that have the same inverter and they each bought a different lithium battery and one make will work and the other not.
Perhaps better to buy from walk in store where you can test it when buying.
1 hour ago, jlr said:
I have 12.8V lithium you more than welcome to come and test the unit on. I am in Centurion.
Thanks for the offer.
Let's see if @Nix
want to go this route or if someone in Centurion can supply a Mecer 720W for such a test.
