August 22, 20232 yr 1 hour ago, Scorp007 said: Any idea how long should one wait? I get this when wanting to reply on a topic. I don't get that. I am guessing you are not in the circle of trust 😀
August 22, 20232 yr 1 hour ago, Scorp007 said: Any idea how long should one wait? I get this when wanting to reply on a topic. Work or home network?
August 22, 20232 yr I suspect an issue with your network - if you are on WiFi trying turn off WiFi and try with your mobile data. Otherwise see if you can try from a different network, no issues on my side and seems most others are not experiencing the same either. Edited August 22, 20232 yr by PsyCLown
August 22, 20232 yr Author 7 hours ago, PsyCLown said: I suspect an issue with your network - if you are on WiFi trying turn off WiFi and try with your mobile data. Otherwise see if you can try from a different network, no issues on my side and seems most others are not experiencing the same either. It cleared up after 5min. Never seen such a msg but while I had the problem other web pages were working fine.
August 24, 20232 yr On 2023/08/22 at 10:34 PM, Scorp007 said: It cleared up after 5min. Never seen such a msg but while I had the problem other web pages were working fine. It is possibly because this website is protected by something like cloudflare. It is just making sure you are a normal user and not trying something like a DDOS attack, etc.
August 24, 20232 yr Author 53 minutes ago, HendrikBigChief said: It is possibly because this website is protected by something like cloudflare. It is just making sure you are a normal user and not trying something like a DDOS attack, etc. Thanks. So for 5min I was a suspect😀😀
