August 28, 20233 yr Is there any reason (except costs) why you would not use 10mm or 16mm for wiring your whole house? Wire Plugs, stove, lights etc with 10mm cable? Edited August 28, 20233 yr by McGuywer
August 28, 20233 yr No use having those think cables when Plug Sockets are rated for 16A. Will also not be able to put 2 or more circuits in 1 pipe. There is really no need. It is also difficult to work with in such small enclosures.
August 28, 20233 yr 3 hours ago, Jacques Ester said: It is also difficult to work with in such small enclosures. Just going by his name, I'm sure he'll find a way...
August 28, 20233 yr 3 hours ago, McGuywer said: Is there any reason (except costs) why you would not use 10mm or 16mm for wiring your whole house? Wire Plugs, stove, lights etc with 10mm cable? Make dependent you might also not get 2x10mm inside a plug socket screw connection as you will have quite a few plugs with an in and out wire looping to the next socket. I would not want to think how you will make the connection for a light. Edited August 28, 20233 yr by Scorp007
