Sunsynk 16kw inverter fuse size?
1 hour ago, Slaaiblaar said:
What size Fuse to use between inverter and battery. 48v system
16000w÷48v= 333amp fuse?
I have never seen fuses that size
It will depend on what battery/ies you connect. Not the inverter size
Use the next size up from the calculated value.
You need 400 frame size, 315-400 fuse switch disconnect with Onesto PVH3-400 400AMP 1000VDC fuse.
https://www.liteglo.co.za/shop/mce-pvh3-400-400amp-1000vdc-pv-fuse/
https://mapleleafelectrical.co.za/products/400-frame-size-fuse-switch-disconnector?variant=41262048739465&currency=ZAR&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2022-07-21&utm_source=google&utm_medium=smart_campaign
