September 2, 20233 yr Hi Does anyone know at what voltage should my inverter cutoff? i have mecer 1200VA with a 105ah LA battery. Currently it cuts out at 12.24 volts. According to the manual it should cutout at 11.8v if i am correct. do you think there could be something wrong with the inverter? Any advise would be highly appreciated
September 2, 20233 yr 22 minutes ago, jaco1507 said: Hi Does anyone know at what voltage should my inverter cutoff? i have mecer 1200VA with a 105ah LA battery. Currently it cuts out at 12.24 volts. According to the manual it should cutout at 11.8v if i am correct. do you think there could be something wrong with the inverter? Any advise would be highly appreciated You must check the voltage just before the inverter switches off as LA voltage tends to rise as soon as the load is removed. Make sure it is not below 12v before inverter cuts out. Edited September 2, 20233 yr by TaliaB
September 3, 20233 yr Author Yes - Voltage rises after rises after switch off, but still think inverter switches off to soon? I had the Multimeter connected again this morning and it switches off at 12.36V. Does that seem Normal?
September 3, 20233 yr 1 hour ago, jaco1507 said: Yes - Voltage rises after rises after switch off, but still think inverter switches off to soon? I had the Multimeter connected again this morning and it switches off at 12.36V. Does that seem Normal? What type of lead acid do you have flooded which you can top up or SLA sealed as they have diffrent soc characteristics if you have SLA as i suspect your inverter is switching off at 55% soc the battery will last longer maybe the thinking behind it of the manufacturer.
September 3, 20233 yr 17 hours ago, jaco1507 said: should cutout at 11.8v if i am correct. That voltage is to low for LA if you look at the chart above 11.8v is 20% the battery will not last at that cut off voltage.
September 3, 20233 yr 2 hours ago, jaco1507 said: Yes - Voltage rises after rises after switch off, but still think inverter switches off to soon? I had the Multimeter connected again this morning and it switches off at 12.36V. Does that seem Normal? This cut out is way above the normal level. Did you measure the voltage on the point of entry to the inverter or is it one of those models where the cable is fixed and terminated inside the inverter?
