September 4, 20233 yr Hi, I have 4 100w panels that are wired to a PWM controller. I would like to add a 100A Dc volt amp display panel + Shunt resistor 100A 75mV FL-2 to measure the volts and amps from the panels to the charge controller. I have tried googling but could not find a schematic to connect the meter. Anybody able to assist please.
September 4, 20233 yr It should be identical to your diagram. You just replace the battery with the solar panels +/-
September 4, 20233 yr 26 minutes ago, PowerUser said: It should be identical to your diagram. You just replace the battery with the solar panels +/- Here is what PowerUser is saying: I think the PV panels have to output less than 28V and I am not sure how they will like the startup voltage. One could put this in the battery loop because PWM current from the panels is the same as the battery charging current... although it might blow up.
September 4, 20233 yr Author Thanks everybody. I will try read up about the start voltage for the meter. I will give it a go in the morning
September 5, 20233 yr Author Ok so I got the meter setup this morning. I have 4 100w panels connected and all seemed good for about an hour or so then the meter cut out. Think I might have blown it. It was supposed to be 100v and 100A meter so wondering now??? Edited September 5, 20233 yr by Malcolm
September 5, 20233 yr 3 minutes ago, Malcolm said: Ok so I got the meter setup this morning. I have 4 100w panels connected and all seemed good for about an hour or so then the meter cut out. Think I might have blown it. It was supposed to be 100v and 100A meter so wondering now??? Are your 4 panels in parallel?
September 5, 20233 yr Author 3 minutes ago, Scorp007 said: Are your 4 panels in parallel? Yes they are in parallel
September 5, 20233 yr 38 minutes ago, Malcolm said: Yes they are in parallel When they are self driven without a Aux supply the maximum volts can only be about 35V. When you want to use it for higher volts you must use the yellow and black wire that was not connected and wire it to a 9-18V separate Aux supply. For up to 60V and 100A you can try this meter which also accumulates Ah, kWh. Also keeps peak amps, peak Wh. These accumulated values can accumulate during the day and reset to zero when there is no power from the panel. Just one point. The Wh resets after about 580 and the Ah after 65 during the day. Power can flow in reverse but no readings will show. Clear source and load prewired with short flying leads. Edited September 5, 20233 yr by Scorp007
September 5, 20233 yr Author 1 minute ago, Scorp007 said: When they are self drive without a Aux supply the maximum vts can only be about 35V. When you want to use it for higher volts you must use the yellow and black wire that was not connected and wire it to a 9-18V separate Aux supply. For up to 60V and 100A you can try this meter which also accumulates Ah, kWh. Also keeps peak amps, peak Wh. These accumulated values can accumulate during the day and reset to zero when there is no power from the panel. Just one point. The Wh resets after about 580 and the Ah after 65 during the day. Power can flow in reverse but no readings will show. Clear source and load prewired with short flying leads. Thanks i will source a meter like this.
September 5, 20233 yr 1 hour ago, Malcolm said: Thanks i will source a meter like this. Bottom left scrolls through all the values recorded while the other 3 are real time values. Handy to always see the Watts without the need for calculating it.
