OG-Plus 5.48 Settings
Hi There,
I recently added solar assistant to my setup and it has raised some concerns, can I please get some help for the settings.
  • The inverter switches of the solar when the batteries are at 97% state of charge and switches back to solar when dropped by 1%. How can I get the batteries to charge 100% and then have solar run the load until solar is unable to manage the load?
  • The inverter keeps updating the settings to 140A, If i understand correctly, the batteries should never be charged higher than 20A per battery, so no more than 80A. Am I correct or what is the correct A for 4x US3000C 3.5KW Pylontech Batteries or is 140A safe for the longevity of the battery?
My setup:-
  • 1x Kodak King 5kw, 4x 3.5kw Pylontech Batteries, 6x 660w Canadian Solar Panels
  • 125A Battery Fuse, 50A Solar Fuse
  • Battery recharge from grid at 20% SOC, Inverter shutdown at 10% SOC
  • Shut Down Battery 46v, To grid 48v, Back to Battery 49v, Battery float and absorption charge 53.2v
  • Max charge 140A, Max grid charge 10A
Any assistance is greatly appreciated and happy to supply additional information if needed.
Thank you.
Hi There,
My setup:-
Thank you.
Are you using 3 parallel strings and do you have fuses for each string or only the 50A fuses between panels and the inverter?
I purchased Solar Assistant and through that interface I managed to find the right settings. After much playing around on Solar Assistant, I managed to resolve the issue. Solar Assistant which was such a huge help in correcting my issue.
Basically i changed the following:-
  • Battery from Inverter settings to Emulated BMS
  • I had both the Micro USB from inverter to Solar Assistant and Voltronic RS232 from inverter to Solar Assistant. I removed the RS232.
Current Connection:-
  • Pylontech Cable from Master Battery to Inverter
  • Micro USB from inverter to Solar Assistant
Changes Experienced:-
  • Battery now shows 100% charge and not 97% at full
  • Solar remains on to manage the load after battery has fully charged
  • No more fault 69 or error 61 with current set up show below
  • Battery charges from the grid at 20%, and not at a voltage spike
  • Max current max charge current of 50A from solar, 10A from grid
Some screen grabs of my setting for Solar Assistant if needed, hope this helps others with similar issues
