November 2, 20232 yr Hi I currently have a Nenergy battery model number AT4880 with a 5kva Growatt inverter. If I want to add another battery does it have to be exactly the same battery model number and everything the same? Cause I have been trying to search for this battery and it seems like everyone is out of stock. Thanks Jaco
November 2, 20232 yr This seems to be a 15cell LiFePO4 battery, if that is the case, pretty much any other 15cell LiFePO4 battery should be ok, to parallel up with this one, even if the new battery has more capacity...
