Solis s6 5kw hybrid pro
Can the solis hybrid s6 pro only supply to the none essential load or do i need to connect the essential loads as well?
I will not be using a battery for now as this is only for getting my electrical bill down.
Regards
Peet
Regards
Peet
The essential can only provide power during the grid off if there is a battery connected.
That is how I see it.
8 minutes ago, Boertjie27 said:
So then no connection to essential loads. Only to grid.
Yes this is how  I have it. During grid on the non essential will feed all solar to your whole DB board and when grid is off the panels and inverter is idle. You then only use the grid tied portion.
