Surplus power
Hi all.
Just had a 5 kva Luxpower and solar array (6 x 550watt panels) installed. So pretty much a newbie to the scene.
As South Africa (Margate Kzn, anyway) does not allow feed back into the National grid with the accompanying credit, Is it possible during the day to route surplus energy from your panels, once the battery is fully charged, to for e.g. the geyser?
1 minute ago, BarryMol said:
Hi all.
Yes you can, as long as you don't exceed the Inverter max output, in you case 5 Kva
10 minutes ago, BarryMol said:
Hi all.
Its possible yes, but it doesn't just take the surplus. Lots of people use automations to get solar forecasts (solcast) for the day or remaining based on hour, combined with battery SOC, Load etc and determine when to run their geysers. Check out Home Assistant
I currently run mine with a more manual approach as I cannot specifically define my approach yet. For now - I have a dashboard which gives me the solar forecast for the next 7 days. Usually check this in the morning to prioritize what's run at home. 95% of the time it's accurate within 1kWh. I then turn on/off throughout the day.
Edited by spotity
7 minutes ago, BarryMol said:
Hi all.
Please note that the max PV on your inverter is 3200 W, if you are only using one tracker you are very close to max.
Good to see the forecast. What size PV do you have?
In which area are you?
I stand to be corrected. The Luxpower takes 3200W per MPPT and there are 2.
36 minutes ago, Scorp007 said:
Asking as I know nothing about trackers
@Antonio de Sa is most likely in this context referring to the mppt or tracker, it is usually one and the same thing sometimes also referred to as the maximum power point tracker ( MPPT)
😉 🤪 🙃 I may be or may not be correct in my assumption of the meaning.
Edited by WannabeSolarSparky
Yep tracker and mppt is the same thing, @Antonio de Sais correct very close to maksimum for 1 mppt the fans are constantly going to run.
7 minutes ago, TaliaB said:
To come to your defense @Scorp007 if you want to be grammatically correct then a solar tracker is when the solar panels track the sun on either 1 or 2 axis sorry @Antonio de Sa😝🤣
Sorry guys for the confusion I created. I mean MPPT. but here is the definition of what MPPT means. MPPT stands for Maximum Power Point Tracker
