ICC + Pi DC power redundancy
GM Pf,
I have on many occasions found the Raspberry PI hanging.Result was a redo of  he ICC image,update and reconfigure.I have lost count on the amount of times
it has been done.
I was considering using the Mecer tablet to the job.
I bought a portable Adata battery bank to use this as a UPS only to find it won't charge and supply power at the same time.
Are there any circuits or silver bullets out there I can put together use to have a shared 5v busbar to allow for continuity?I have also purchased a power cube from Builders with ac  and 2 DC outputs.
Thank you.
FG
On 2018/10/26 at 5:29 PM, SolarNoob said:
Have you considered the UPS hats for the Pi?
https://www.pishop.co.za/store/index.php?rt=product/search&keyword=ups
I note that one of those UPS things has an UltraFire branded cell as the backup. A colleague and I assessed one of those cells 2.5 years ago, and found that they were complete rubbish. The active material was a loose fit inside the case, and they had a capacity perhaps half of what was claimed. So I'd be wary of any product that uses them, or even has them in an image on their web site.
