Hello from Oz
Thanks for the join. Seems a very knowledgeable and friendly forum.
I have been on my solar journey for about 10 mths now, but only been fully off grid for the last 2 months when I moved to a bush block in country Victoria.
Living in a Tiny House which I designed and built. I have all the mod-cons and the system is coping beautifully, (specs below).
Plenty of sunshine here in summer - from 75% to fully charged - usually done and dusted by midday. Will be interesting to see how I go in winter.
Cheers, Baz
PS: I do have a problem with my generator not playing nicely with the inverter, in which section of the forum should I ask for help?
(6 x 250W Poly PV. 4 x 200A Ritar batts. MUST 80A 5000W Inverter/Controller. Victron BM700 monitor).
Welcome Bazza. Nice setup you've got there, looks like a Must or Rebranded Axpert inverter you are using.
You can ask in the "Questions and answer" section. Or even under inverters in your case.
I think that the MUST inverter is an Axpert knockoff and not a rebrand, so the menu's and settings are not the same. See if you have an Appliance/UPS option, if you do then set it to appliance which is more tolerant of voltage fluctuations.
