August 20, 20197 yr If you had a Victron installed i could`ve halped you. We can AC couple to Victron with ABB connected to a Kestrel wind turbine.
August 20, 20197 yr so would your E2301 not work ? I see output could be 110 Volt DC E230I (800W) AVAILABLE IN 12, 24, 48, 110 AND 200 VDC
August 21, 20197 yr To allow the Inverter to control the power output better as to not pull the turbine to a standstill if there isn`t enough wind
