Solar charger in Hybrid Inverter
Martin1971
Hi guys
I have a Fivestar 5KW inverter with 4 Canadian 380W panels. For a few days now it seems that the solar charging circuit doesn't work. When Eskom goes off, the battery starts working and the panels stay on 76V @1A. This is constant reading regardless if loadshedding is on or not. Is the solar charging busted?
Regards
Martin
I'm guessing that this is an Axpert clone, the PV input is 145 V max, and the  panels are wired 2S2P.
That's the only configuration for which a PV voltage of 76 V makes sense. 1 A at the output (so that's around 50 W not around 76 W) usually means that the panels aren't ramping up as yet. There can be various reasons for this.
Has the inverter been working for some time before this recent change?
What is the output source priority? I don't know what setting that would be on a Fivestar. It might have a name like SBU, SUB, UTI, etc.
Is utility battery charging working?
It's not looking good, but it could be a number of issues, you didn't give us much to go on.
Thank you Coulomb
The voltage on the side shows 60V - 105V for panels, so I think the 76V for 2x 380W panels is a good sweet spot. I normally got between 6A and 11A depending on my load for the day. My system is as follows.
Fivestar 5KW Hybrid inverter
4x 380W Canadian panels 2 series pairs in parallel (760W + 760W)
2x Greenrich 100A lithium batteries
Everything worked great until last weekend.
So that's a PWM model. In bulk charging stage (most of the time when charging the battery), the panels should be connected across the battery, i.e. you should see about 53 V, not 76 V. So it does look like it's not charging, or is trying to charge and failing.
If you give us the exact model of 380 W Canadian Solar panel, we can check the Voc. But I think it's going to be around 76 V, so these are probably 72 cell panels. Even if they are 84 cell panels, the Voc is not going to get near 105 V.
Do you have a charge LED on your Fivestar? Is it off, on solid, or flashing?
Edit: Is it this model? https://nm-tech.co.za/products/five-star-5000w-5kva-48v-hybrid-inverter-80a-mppt
Parts say it's PWM, other parts say it's MPPT, ugh!
5star-1_06e8d896-9f96-4394-b102-7e90a0a7
Here are the specs. and models. As I said previously, everything worked great and suddenly not. Will do fault finding today and check the panel wiring.
Thank you for all the advice and help.
Martin
