February 13, 20197 yr I am often told to only look at the 4.6kw Es and not the 5kw EM. Can someone with Goodwe experience please give reasons for this. In terms of flexibility with configuration, How does the Em compare to the ES? @Mike, @Fuenkli your thoughts?
February 14, 20197 yr i have not used the EM version, but i think it has a newer firmware and the backup load is lower ( 2.4 or 3.6) as opposed to 4.6 on the ES. The new SENS site to monitor is problematic, with many unable to login / on....
February 14, 20197 yr 17 hours ago, Jaco de Jongh said: How does the Em compare to the ES do not know the EM series. But based on the published specifications they seem to be identical except that battery charge/discharge capacity is lower than on the ES.
