Gordon B
Hi Guys, my query relates to a HYBRID SOLAR INVERTER 5000VA 48VDC WITH PV INPUT.
I have installed & wired up the system to factory spec.
Unit operated well but I do not get an PV input displayed on the LCD
The dealer supplied only one 145 watt panel, will this work ?
Gordon
Gordon
Only one? If It is a 36 cell panel, you will need, at least, four pannels.
Edited by Javi Martínez
That sounds awfully generic. Does it have a brand name?
As Javi mentioned, no. You will need at least 60 VDC from the panels. A single 145 W panel sounds like a totally impractical sales gimmick.
There is one possible exception (though I am pretty sure I am just confusing things by mentioning this... so if it confuses you then forget that I said anything), and that is if you use a boost-converter type MPPT. Like this Ming He MPT-7210A. Interesting idea, but since 145W is so low anyway, the right answer is almost certainly to get more (or different) modules. Otherwise it is worse than a sales gimick. It's a downright scam.
I thouht the same, but... Even using a boost, it wouldn´t be enough to maintain quiescent draw with only one panel!
