June 11, 20242 yr Hi anyone,I’m new to the forum and am obviously looking for advice. I want to install 4 floodlights on the outerwalls of my house (just under the eaves) - can I run the 4 cables in the roof to connect to a plug box in the roof? The plug box was installed by an electrician many years ago to connect to a light socket in the roof. If yes - must the cables run through pvc pipes / trunking or just tacked to the rafters? TIA
June 11, 20242 yr 2 hours ago, QuintonB said: Hi anyone,I’m new to the forum and am obviously looking for advice. I want to install 4 floodlights on the outerwalls of my house (just under the eaves) - can I run the 4 cables in the roof to connect to a plug box in the roof? The plug box was installed by an electrician many years ago to connect to a light socket in the roof. If yes - must the cables run through pvc pipes / trunking or just tacked to the rafters? TIA You can use twin and earth or round surfix but not from a plug socket.
June 13, 20242 yr Both the cables Scorp007 mentioned can either be clipped direct to rafters or run inside conduit. Some brands of surfix and flat twin & earth cables are rated as UV stable but not all so if you want to clip it outside in view of the sun check the manufacturers data sheet to see if it's UV stable.
June 14, 20242 yr This is what the regs says regarding luminaries. 6.14.1.4 In a lighting circuit, a luminaire that is in a false ceiling or in a roof space 4 m above the floor where there is no ceiling, or in a floor cavity, or in a wall cavity, or in a similar position, may be fed from a socket-outlet which may be unswitched and not protected by earth leakage protection, provided that the socket-outlet b) supplies one luminaire only, not exceeding the rating of the socket outlet⁹ Edited June 14, 20242 yr by TaliaB
