16Kw sunsynk inverter
2 hours ago, Jeanq5 said:
i would like to know how many oanels can a 16Kw inverter sunsynk take.
Regards
The maximum DC input power is 18kw.  3 x mppt's mppt 1 2 string input mppt 2 2 string input mppt 3 2 string 22A/ Mppt. Voc= 450v
Edited by TaliaB
3 hours ago, TimCam said:
The current Sunsynk 16 kW inverter is a beast. 3 * MPPT Max Operating Current = 26A+26A+26A,  Max Short Circuit Current = 44A+44A+44A.
Max usable PV = 20800W.
See below for Datasheet.
Yeah for sure the above is version V9 May 2024 the op needs to check which version he has there is version V2 that was released and installed in 2022 that is still sold that has a lower pv rating of 18kw best to check the manual supplied with the inverter.
Edited by TaliaB
