September 15, 20241 yr Hi guys Is it possible to use this inverter just as a grid tied inverter? No battery. Thanks
September 15, 20241 yr @Voltagezait's possible. There is a setting under battery Parameters to select NO battery. If you place the machine with no battery & have it in Self use mode it will use the PV power as a Grid tied machine. Then you need to define Grid export or zero export via the CT settings.
September 15, 20241 yr Author Thanks @Steve87 Do you know if the Sungrow SH6.0RS Residential Hybrid Single Phase Inverter can do the same? Thanks
