Software AXPERT Kingll 6kw
On 2024/11/08 at 7:02 PM, ahmad almawal said:
Note that U1: 60.11
I'm not  familiar with any firmware for King IIs that is 60.xx, but then again I don't seem to have any that are rated at 6 kW.
Are you certain that it's not a VM III model? The VM models are notorious for the fan noise, though there are some quieter firmwares out there.
Thanks. That does look like an Axpert King II 6 kW, quite possibly genuine. Unfortunately, I have seen no firmware for it.
Strange that the VM III and VM IV 6 kW models also have 60.xx firmware. I wondered if they tried to merge these firmwares, but QMN returns (VMIII-... as expected for VM IIIs and VM IVs), and there is no QGMN command, as expected for Kings and King IIs.
14 hours ago, ahmad almawal said:
I don't see the percentage sos %
Is this on the display of the inverter itself, or via monitoring software?
If monitoring software, which one?
If it's Solar Assistant, what is the "driver" for this model?
I'm thinking now that yours is a clone, inexpertly put together. I'd say it's a VM III clone, hence the noisy fans. 60.11 is a Twin main firmware (for VM  III new, but there could well be firmware numbering overlap with Axpert King  6kW), yet U2 19.18 is a non-Twin display firmware. If I'm right, it's surprising that it works at all. But this is all highly speculative on my part.
