December 22, 20241 yr Hi there! Looking for some advise. My heat pump has been a dream but all of a sudden it doesn't seem to heat my water. heat pumpkins and pump seems to be working, but just not heating water at all. Is there a DIY fix or a way to check what the problem is? Thanks in advance!
December 23, 20241 yr On 2024/12/22 at 11:37 AM, GraemeGullacksen said: Hi there! Looking for some advise. My heat pump has been a dream but all of a sudden it doesn't seem to heat my water. heat pumpkins and pump seems to be working, but just not heating water at all. Is there a DIY fix or a way to check what the problem is? Thanks in advance! Possibly one of two things usually, the gas needs to be topped up or the cap died. A technician will find and fix it fast.
December 23, 20241 yr On 2024/12/22 at 11:37 AM, GraemeGullacksen said: Hi there! Looking for some advise. My heat pump has been a dream but all of a sudden it doesn't seem to heat my water. heat pumpkins and pump seems to be working, but just not heating water at all. Is there a DIY fix or a way to check what the problem is? Thanks in advance! Does your heat pump have a display readout if it has it should give you an error code then check in the manual wat the error code indicate.
December 23, 20241 yr On 2024/12/22 at 11:37 AM, GraemeGullacksen said: Hi there! Looking for some advise. My heat pump has been a dream but all of a sudden it doesn't seem to heat my water. heat pumpkins and pump seems to be working, but just not heating water at all. Is there a DIY fix or a way to check what the problem is? Thanks in advance! You don't mention the brand. If it's a Kwikot then you and I can swap notes and see what we find.
