March 19, 20251 yr Do BMS software applications work on MAC devices?As far as I know, Windows EXE programs can be run on a MAC, but I'm specifically wondering if BMS applications would function properly, especially since they rely on device utility ports. Edited March 19, 20251 yr by esmail-kassir
March 19, 20251 yr 1 hour ago, esmail-kassir said:Do BMS software applications work on MAC devices?As far as I know, Windows EXE programs can be run on a MAC, but I'm specifically wondering if BMS applications would function properly, especially since they rely on device utility ports.Yes, there is support - https://diysolarforum.com/threads/eg4-bms-tools-and-bms-test-for-macos.67917/
March 19, 20251 yr Author 3 minutes ago, Demo said:Yes, there is support -I ment to run the windows version on MACBecause not all vendors provide MAC version, for example Felicity batteries doesn’t
March 20, 20251 yr 10 hours ago, esmail-kassir said:I ment to run the windows version on MACThe older Mac's with Intel hardware is straight forward install, some models require boot camp, have a look here - https://support.apple.com/en-za/102622
March 20, 20251 yr I am also on a Mac and face similar issues. I have an intel based Mac and have had to run VMware Fusion in order to circumvent some of the issues of not having support natively on a Mac and even with VMware fusion there's still things that a normal user without some technical knowledge would struggle to get done.
March 20, 20251 yr Author 2 hours ago, Moffat said:I am also on a Mac and face similar issues. I have an intel based Mac and have had to run VMware Fusion in order to circumvent some of the issues of not having support natively on a Mac and even with VMware fusion there's still things that a normal user without some technical knowledge would struggle to get done.nut in general you could mange to run exe program that monitor battery on MAC , right ?
March 20, 20251 yr 11 minutes ago, esmail-kassir said:nut in general you could mange to run exe program that monitor battery on MAC , right ?Yes am able to run pmbsTools to connect to my eTower battery and see and monitor my battery performance in detail including individual cells, voltages and temperatures etc...
March 23, 20251 yr Author On 3/20/2025 at 3:27 PM, Moffat said:Yes am able to run pmbsTools to connect to my eTower battery and see and monitor my battery performance in detail including individual cells, voltages and temperatures etc...Thank you <3
