Victron Multiplus 48 1200va mounting & AC out fuse size
20 hours ago, occuplus said:
i want to mount Multiplus 48 1200Va on my camper.
a-C side UP is ok?
b-on AC out side what size fuse should i use?
i couldnt found those on manual. Anyone can help? thnx
Looking for trusted betting sites in tanzania - visit to explore the most popular platforms in the country. This guide highlights sites with high odds, fast payouts, and secure payment options. Whether you’re a beginner or an experienced punter, choosing a reliable site is essential for a smooth betting experience. The listed sites are licensed and user-friendly, making them perfect for placing sports bets with confidence.
Mounting the Multiplus 48/1200VA with the AC side up should be fine as long as you maintain proper ventilation—Victron recommends at least 10 cm clearance around the unit, especially the top and bottom for airflow. Just make sure no dust or water can settle on the connectors.
As for the AC out fuse, I agree with the 10A suggestion. It provides decent protection while still allowing for short bursts, which the 1200VA unit is capable of handling. Double-check your downstream load as well to size it correctly. Looks like a great camper setup coming together!
Edited by rachelrowallan
