May 31, 20251 yr Hey everyone I am completely new to home assist and solar systems. In few weeks I will be getting sunsync 10kw battery and hopefully 7kw invter as these are going out side it would be bit of pain to run cales from invter into my pi/ computer depending on what I use, I was looking at solar assit but sue to them going out side I am now looking into home assistSo if anyone in generous to help or answer few questions for me.1.) Will the sunsync dongale work to pull everything I need to edit export times / import times and be able to do it automatically rather than manual as I will be switching to octopus flux and you have set it manually In sunsync app.2) what addons would I need to set it automatically import/ export from octopus flux .3) any other help full addons to help stream this when I get my solar installed
September 1, 2025Sep 1 @WelshDragon80 ,I suggest you go and check out Heinz's HA solution for Sunsynk/Deye for Octupus Flux (& other European Power Utilities). Works brilliant. His dongle (installed @ inverter) converts/connects via Wifi to your RPi/PC, so no long cable runs to install.https://smarthomeintegrations.co.za/https://www.youtube.com/@SmartHomeIntegrations/videosAlso https://github.com/tomatensaus/DeyeSolarDesktop
