June 24, 20251 yr Hi, I've got 2 evo energy 6.1 batteries that I won't be using for a year, any suggestion on how to store these and charge them etc, any suggestions will be helpful
June 24, 20251 yr @SJB for normal NMC type Lithium cells the suggested handling is charge or discharge to 50% of SoC and then put in them in the cupboard, don't know what cell type yours had, but even LiFePO4's I would treat the same...
June 24, 20251 yr @SJB Google search for LiFePO4's comes up with the following...To properly store LiFePO4 cells for future use, ensure they are at a moderate state of charge (around 50%), kept in a cool, dry place away from extreme temperatures and direct sunlight, and monitored periodically for voltage. Here's a more detailed breakdown:1. Charge Level: Ideal Range: Store LiFePO4 batteries at a charge level between 50% and 80% according to ACE Battery. Avoid Full Charge/Discharge:Do not store them fully charged or completely discharged, as this can negatively impact their lifespan according to ACE Battery. Monitor:Check the voltage periodically (every few months) and recharge to the ideal range if necessary. 2. Temperature and Environment: Ideal Temperature: Store them in a cool, dry place with a temperature range of 15-25°C (59-77°F). Avoid Extremes: Extreme temperatures, both hot and cold, can damage the cells. Humidity: Low humidity is preferable to prevent corrosion according to Canada.ca. Sunlight: Keep them out of direct sunlight, which can cause overheating. 3. Other Considerations: Original Packaging: Store them in their original packaging or a similar protective container. Separate Storage: If storing multiple batteries, keep them separate to prevent short circuits. Cleanliness: Ensure the battery terminals are clean and free of debris. Disconnect: Disconnect the battery from any loads or chargers during storage. 4. Important Notes: Self-Discharge: LiFePO4 batteries do experience some self-discharge over time, so periodic checks and charging are necessary. Degradation:Calendar aging (degradation over time) is unavoidable, but proper storage can minimize its effects according to Zitara Technologies. Recycling:If the batteries are spent or damaged, explore recycling options instead of disposal.
