November 15, 2025Nov 15 Hello, I need the firmware for the VMIV TWIN 4K inverter.I am encountering a problem: the inverter is showing Error 32 on the screen..
November 27, 2025Nov 27 Error 32 means the screen cannot communicate with the MCU. This can happen if you have a hardware failure of the SPS circuits or a disconnected/damaged cable. These are most common cause of F32 that I have seen and a firmware update won't help. I suggest checking the main board for faults.
December 8, 2025Dec 8 Another possible reason for warning code 32 is if the last firmware update was incomplete. In that case, the bootstrap loader program detects this situation, and rather than allowing the faulty firmware to crash, it stays running, waiting for another firmware upload. The bootloader is very simple, so it can't even let you know that it's running. So the inverter looks like it's totally bricked, other than the display, which runs totally separate firmware on another CPU, and it shows warning code 32 because all the commands it sends are timing out with no valid response.If this is the case, merely restarting a firmware upload will often start the reflash process again, and assuming that it eventually succeeds, the inverter will spring back to life. See If you think your inverter is Bricked.
