What is the role of OP0C IC in solar inverters
Hi all,
I am wondering what is the purpose of the IC in the modern inverters
I see many posts talked about comparing batterh gnd and output neutral but I don't understand why
Can any one explain?
32 minutes ago, Adnano said:
Hi all,
You should not connect an inverter's neutral to the grid's neutral because it creates dangerous "ground loops," causes "nuisance tripping" of safety devices (like RCDs/Earth Leakages), violates electrical codes (by converting TN-S to TN-C systems), and introduces phantom voltages (like 60V) onto the ground wire, making the system unsafe and potentially damaging equipment. The neutral-ground bond should only happen at the main service panel, not at the inverter, allowing the inverter to act as a floating source when off-grid and correctly sense faults.
Key Dangers & Problems:
  • Ground Loops & False Trips: Bonding neutrals at both the inverter and the main panel creates multiple paths for current, causing earth leakage (RCD) breakers to trip unnecessarily and creating dangerous potential differences.
  • Violation of Standards: It effectively turns a safe TN-S system (separate Neutral & Earth) into a TN-C system (combined), which is illegal in many places and invalidates Certificates of Compliance (CoCs).
  • Phantom Voltages: Unbonded inverters can have "ghost" voltages (e.g., 60V) between neutral and ground; bonding them connects these real voltages to your earth, making the ground wire live and dangerous.
  • Harmonic Distortion: A solid neutral connection interferes with the inverter's ability to detect grid issues, as harmonics can flow through it.
  • Equipment Damage: Some inverters are not designed for this and can burn up or malfunction when the neutral and ground are bonded incorrectly, notes a Scribd article
Correct Practice:
  • Bond at the Main Panel: The neutral-ground bond (N-G bond) belongs only at your main distribution board, where the grid's neutral and earth are bonded to the main earth spike.
  • Inverter as Floating Source: When off-grid, the inverter acts as a "floating" source, similar to a generator. It should only bond its output neutral to an earth spike (or the house earth via a relay) when it detects it's truly isolated from the grid, as per its design.
  • Use Transfer Switches: Use an automatic transfer switch (ATS) that moves the neutral alongside the live feed to switch between grid and inverter power, maintaining the correct bonding point at the main panel.
