Axpert mks 5000w parallel compatabillity
Hi all, I have 2 Axpert MKS 5kw inverters connected in parallel. I want to add a 3'rd one, but can not find one. Can I connect it with the MKS-II ?
No you generally cannot parallel an existing Axpert MKS 5 kW inverter with an Axpert MKS-II 5 kW inverter.
They’re different models/firmware generations, and for stable parallel operation Voltronic/RCT-style inverters need to be the same model and very similar firmware so they can communicate phase, current share and master/slave roles correctly. Mixing an MKS with an MKS-II is not supported and is likely to cause errors, sync problems or faults.
20 minutes ago, TaliaB said:
@Shockin @Oros That will work nicely👏 just ensure identical firmware.
56 minutes ago, Shockin said:
I yave one of these from voltex if it helps you
@Shockin what price are you looking for?
Perfect thank you very much!!!
My number is 0828745099, Eric, please send my your details and address so that I can make a plan to get the stuff!
