Inverter Aircon vs normal one
I have a simple question.
When someone buys an inverter air conditioner, is the main reason to save electricity, or mainly to avoid the frequent compressor startups of a traditional AC?
In other words, should we think of inverter AC primarily as an energy-saving technology, or as a way to eliminate on/off cycling and high starting current?
I would be interested to hear opinions
Yes, controlling cooling to match a setpoint is more energy efficient than hunting for it with on and off cycles.
42 minutes ago, hoohloc said:
significantly reduce electricity consumption
I am not sure how much "significant" would be. Running at 100% loading, an inverter AC won't be more efficient than conventional. Both inverter ACs and conventional ACs are power hungry devices that should be used as little as possible.
I have a older normal 12k btu AC and a new 12k inverter, the difference in power usage under the same conditions is about 1600w vs 900w .
Edited by Demo
spelling
In summer (cooling only) yes, but if you use it to heat a room in winter, the figures will be a little different. That's my experience in anycase. I decided to install an 18000BTU TCL inverter aircon in my home office, and was so impressed with its efficiency that I installed another 24000BTU TCL inverter in my living room, all on a baby 5K Sunsynk inverter. Both worked well during the summer and I have used both simultaneously for many hours. I did some testing on the heating side though, and it consumes about 10-25% more power, all depending on a number of factors.
Yeah, cooling only ☺️
