New to Solar - Trying to decide how best to spec a system
6 hours ago, Koch903 said:
I am slightly worried that 10kwh battery is not enough
First of all i would like to know from @Koch903 are the Sungrow inverter quoted 48v system or Hv battery system. If you are looking at the Sungrow SH10RS class it uses Hv batteries. Which battery module where you quoted on the SBR or SBH. The SBH is Sungrow’s newer higher performance platform where each module is 5kwh. The SBR modules are 3.2kwh.
Hv inverters are more effiecient ( if Sungrow Hv) handles high loads much more gracefully than the 48v counterparts. I agree with @frivan Sungrow are definitely inverter system to consider.
Yes it’s the SH10RS and SBH batteries. a bit of research has shown me that I that the max discharge rate is 50 amps which given the high voltage would limit me to approx 7kw in off grid and no solar, similar as @Mattyboy put it the Dyness is limited to around 10kw in off grid mode given its discharge rates.
I don’t think this is a limiting factor.
I’m really leaning to the Sungrow based on the feedback
I have made the choice to go with the Sungrow system - Installation will start after the public holiday next week, and I should be up and running at the end of that week. Now to start thinking if I incorporate Home Assistant and automations from the get-go - especially for the geyser.
Exiting times 😊Good luck with the install, and enjoy your system's performance.
