Mecer 5kva Inverter - Question
  • Replies 50
  • Views 22.1k
  • The SOL Output Priority setting seems to be for the situation where you want your batteries as full as possible for as long as possible, to be ready for load shedding for example. It should run in bat
  • The recommended (by the consensus of this forum, not the manufacturer, they don't know what they're doing 😐) values are 52.5 V and 51.8 V respectively. The higher voltages in conjunction with overshoo
