Sunsynk Sun-batt 5.32 on Solar Assistant
Hi,
I currently have a Sunsynk 12kw single phase inverter hooked up to solar assistant running on an orange pi using the RS485 connection and the cable splitter. The battery BMS is connected to the inverter with the CAN connection.
Unfortunately the Inverter only sends forward minimal battery information. However, the batteries do have an RS232 connection port next to the CAN connection port.
According to Solar Assistant (https://origin.solar-assistant.io/help/battery/sunsynk), you can connect both, however I have also been advised that the BMS software will not communicate on both ports.
Has anyone else tried this, and is there any danger in trying?
Many thanks
Edited by Geoffles
I have a single ESP32 dev board with an RS485 transceiver that is connected to my Sunsynk inverter and all 3 of my Sunsynk Sun-batt 5.32 batteries on a single RS485 bus. Using ESPHome, I have full visibility into the inverter and battery metrics for all 3 batteries, including individual cell voltages in Home Assistant. I can also make config changes to the inverter from Home Assistant. The inverter still communicates with the battery bank using a CAN connection. It is quite a nice solution as the ESP32 is powered by the inverter's 12 V rail. I got the info from this post but just extended it by adding connections to each battery.
https://powerforum.co.za/topic/25195-a-much-better-way-of-connecting-home-assistant-to-your-deyesunsynk-inverter/
Edited by Gambit
23 hours ago, Sidewinder said:
@Geoffles
With the right RS232 cable, you should get most battery info, except the individual cell voltages!image.png
Ok - so does this mean that you can presumably use the RS232 to SA and the CAN to the inverter at the same time?
Very cool - I shall investigate as well
I guess the simplest route would be to extend your Orange Pi solution by adding your battery Modbus IDs and their Pace BMS Modbus registers. Then connect your batteries to the same RS485 cable that is connected to your inverter. If you want, I can provide the Modbus registers I have configured on my ESPHome. I had to change my inverter's Modbus ID to 10 because the batteries automatically assign Modbus IDs starting at 1. (1, 2 and 3 in my case)
Edited by Gambit
