May 2, 20197 yr Does anyone have experience or references for Ritar batteries? They are supplied by Deltec nation wide. All I have is U Tube video indicating that it is manufactured in Spain.
August 7, 20197 yr I have Ritar OPZv2-490's. Based on my use and the specifications they should last 16 years. I have had failures after a year. So far i have replaced 5 cells.
September 16, 20196 yr On 2019/05/02 at 9:06 AM, Novice said: Ritar 200Ah AGM are quite popular in my part of the world. I have used the ones from Vietnam with only one failure when the electrolyte started leaking from the negative terminal. Usually the alternative when I can't find Gaston (India) polygel batteries locally.
