Trojan t105 charging
I have a 60 amp microcare mppt,it only has a bulk and float charge setting,i have the charge settings to data sheet,at 3pm it goes to float charge and i check the soc of the batteries and its not near fully charged but floats at 1.2 amps,the soc only goes to green after equalising batteries
3 hours ago, [email protected] said:
... the soc only goes to green after equalising batteries ...
Have a chat to Microcare?
You must check the time and the amperage settings that decide when the MPPT goes to float. I don't have the manual handy, but after the bulk charge when the amps drop below a level that you can set and stay there for a set time, then it goes to float. Your amp setting may be too high.
I have a similar setup and want to know what settings have you eventually used on the microcare MPPT ?
