May 21, 20197 yr Avie the owner of Solar Solved Cape brings in container loads directly from Voltronics, six years ago I got him to start bringing them in instead of the small quantities i was bringing in. He also has spares for repairs in house sent with every container..
May 22, 20197 yr 12 hours ago, Mike said: He also has spares for repairs in house sent with every container I've always found that a little amusing. Like that time we ordered a big 3-phase generator from Adendorff. Came with a made-somewhere-in-the-east engine that was clearly a Yanmar knock-off... and it had a lamp bolted to the side (so it was from some small tractor). Came with this little plastic tool case, and inside was a complete gasket set and a piston ring... it's almost as if they expect that you might need it... Same thing with some cheap power tools I've bought. Came with a second set of brushes.
May 22, 20197 yr 2 hours ago, plonkster said: I've always found that a little amusing. Like that time we ordered a big 3-phase generator from Adendorff. Came with a made-somewhere-in-the-east engine that was clearly a Yanmar knock-off... and it had a lamp bolted to the side (so it was from some small tractor). Came with this little plastic tool case, and inside was a complete gasket set and a piston ring... it's almost as if they expect that you might need it... Same thing with some cheap power tools I've bought. Came with a second set of brushes. yep, they send a few spare mainboards, mppt board and some fuses with every order..
