June 10, 20197 yr How long after a COC was issues is it valid for? Eskoma accidentally closed my account, apparently operations closed the wrong account. My decision, seeing though i do no use Eskom power is to rather just get a prepaid meter installed, but Eskom requires a COC. I have one that was issued in November 2017, so its about 19 months old. Would i be ale to use i?
June 10, 20197 yr 6 hours ago, stoic said: How long after a COC was issues is it valid for? If I am not mistaken, its only valid for 24 months if no alterations are made during this time.
June 10, 20197 yr https://www.cch.co.za/news/what-do-you-need-to-know-about-home-electrical-certificates-of-compliance/
June 11, 20197 yr 7 hours ago, The Terrible Triplett said: https://www.cch.co.za/news/what-do-you-need-to-know-about-home-electrical-certificates-of-compliance/ That clarifies/confirms it then. From the above link:
June 11, 20197 yr The 2 years makes a whole lot of sense to me now after my fiasco on the earthing and why it is a very good idea to first check ones DB before you buy a solar inverter. As I said before, first check your DB before you buy a solar system. The cost to fix what is could come as a rather nasty surprise, as I learnt. At the time of the checks use the time productively and start the splitting of the circuits off the main DB to the solar DB, in anticipation of the solar install.
