June 27, 20197 yr 1 hour ago, SamSA said: Anyone using a Mecer 4Kw Infini Hybrid inverter. Experience ? Concerns? Can you be more specific about the exact model. If it is the same model I think it is, there is some concerns. These models prove to be an issue in parallel setups. I havn't heard of them giving problems as single units, but in parallel connections they tend to blow components.
June 30, 20197 yr Author Quote received for a grid tied solar setup with a single Mecer 4Kw Infini Hybrid inverter.
July 1, 20197 yr It’s the same as the infinisolar hybrid super 4K. Do a search on the forum as a lot has been written. I thought its off the market so you’ll be getting an obsolete model from a no-care supplier. It’s not on the manufacturers website anymore. @Jaco de Jongh has a used one for sale now.
