August 2, 20197 yr Hi all, For some time now ICC Software says there is a new version for download. Problem is the new version is 2.8.5. I am currently on 2.8.8. Anyone seeing this as well? Also, for two days now, I have to restart ICC for my schedule to kick in, strange.
August 2, 20197 yr When I upgraded to 2.8.8 the first tab on ICC also showed a version number of 2.8.5 and still does after the upgrade. Yet it now shows that I am running the latest version on the settings tab. Checking for an upgrade also shows 2.8.5 as the latest and final version. Perhaps you should try downloading and installing the version on the ICC website and see if that works. I would expect that the activation code will remain the same as long as you use the same RPi. Just keep your current SD card intact in case it does not work out.
August 2, 20197 yr Author Thanks, in upgrade and it installed ver. 2.9 but, it did not connect to the inverter even after several restarts. I downgraded to 2.8.8 before it could connect. I believe there is either a problem with the software or the inverter is faulty.
August 2, 20197 yr None of my business but in chatting with @Manie earlier this week, best is to contact him direct. Back to the Blue side I go. 🙂
October 23, 20196 yr Tonight I discovered that even though my ICC Pi says it's running the latest version (2.8.5) there is version 2.99 out and guess what? You have to pay to upgrade it! I discovered this because I was trying to get info on how to control the geyser and pool pump using Advanced Power Manager that came with the ICC-Pi. Long story short I apparently have to buy the ICC upgrade then buy APM or GPIO if I wanna have the control I'm looking for yet APM was bundled with my Pi.. I'm confused..
June 2, 20206 yr On 2019/10/04 at 8:50 PM, PurePower said: Version 2.8.5 is problematic. You better off on 2.8.8 What issues have you seen with 2.8.5?
