August 27, 20196 yr 4 minutes ago, isimobile said: , I see a similar question was already asked in the Victron community, https://community.victronenergy.com/questions/212/ess-suggestion-for-better-battery-use.html, about max discharge, Have you seen it before? That's @The Terrible Triplett... 🙂 (Hope it's okay to tie a real name to the nick... if not I will edit).
August 27, 20196 yr Author 12 minutes ago, plonkster said: That's @The Terrible Triplett... 🙂 (Hope it's okay to tie a real name to the nick... if not I will edit). Yeah, would have like there to be an option to change you nick...., see you cannot change it on the community site. [Edit] I see you can, Under "My Preferences" change Real Name to your nickname. Edited August 27, 20196 yr by isimobile
August 27, 20196 yr BTW, I cobbled together a minimal python hello-world flask app that should install and run from /data. Haven't tested it yet, but it's a start. It includes schedule, so in theory it will be very easy to do all sorts of magic stuff. At the moment it just says "Hello world", but it has jinja2 for templating, so one could easily extend this into a full blown app. It includes a service directory so it can be started by just symlinking that into /service, but for just development you'd do (assuming you scp'ed the tar file to /tmp): cd /data tar zxf /tmp/venusflask.tar.gz cd venusflask/service ./run And that starts up a flask server on port 5000 that you can hit with a browser. See attached. venusflask.tar.gz
August 27, 20196 yr Author 20 minutes ago, plonkster said: And that starts up a flask server on port 5000 that you can hit with a browser. See attached. venusflask.tar.gz 1002.08 kB · 0 downloads Yeah, this is great.. Have it running :)... This open lots of possibilities.... Play time.... Thanks for this, Ok I have to work, but will start doing some research. BTW, I added a retry function to your pvoutput.org script, busy testing it, post message would fail after a few days, hopefully the retry will work. New to python, but learning in spare time. Edited August 27, 20196 yr by isimobile
August 27, 20196 yr 31 minutes ago, isimobile said: BTW, I added a retry function to your pvoutput.org script, busy testing it, post message would fail after a few days, hopefully the retry will work. New to python, but learning in spare time. That script needs to be completely redone to use the values from systemcalc. That would make it so much simpler.
September 3, 20196 yr On 2019/08/19 at 2:32 PM, isimobile said: 1xVictron MPPT 150/85 16 x 330W panels on a MPPT 150/85? What is the setup? Love the system by the way.
September 3, 20196 yr 21 minutes ago, Corné said: 16 x 330W panels on a MPPT 150/85? What is the setup? Don't see how. 15 is max I can make fit.
September 4, 20196 yr Author 20 hours ago, Corné said: 16 x 330W panels on a MPPT 150/85? What is the setup? Love the system by the way. 20 hours ago, The Terrible Triplett said: Don't see how. 15 is max I can make fit. Maybe this way, thoughts below? I know did not the install myself, so the above setup seems to be what was done, I think. Also I know I have two strings coming down split equally, I think, because it go's to two fuses, to from their to the MPPT. This is what I see on VRM:
September 4, 20196 yr 40 minutes ago, isimobile said: Maybe this way, thoughts below? This is what I get with 2 x 8 - not Accepted. Refresh the Excel, it sometimes gets stuck.
September 4, 20196 yr 46 minutes ago, isimobile said: This is what I see on VRM: Looks like it has not reached full potential yet, system is idling. Note: With the calcs on that Victron Sheet, make sure you load the Temp Coeff - makes a huge difference sometimes.
