Synerji invertor
Hi guys
Great reading all the posts on this forum, very interesting
Would like to know if anybody has any experience with the synerji 12kw invertor?
I have installed a couple of these invertors before and have never had an issue, but my latest install something is happening wich i do not understand, during the day the system works 100%, but in the evening the invertor shows a load of 2,8kw wich depletes my batteries quickly, but the actual load is around 850w, even if i bypass the invertor through the change over switch or switch off all loads the invertor still registers a load of around 2kw
Any advice
Clifford
Is the bypass before or after the inverter? If its after the inverter the only thing that makes sense is that its feeding 2kw back to grid or the loads before the Inverter.
