October 4, 20196 yr Next you must think of a way to preheat the water going into your geyser with that method........😉 Edited October 4, 20196 yr by DeepBass9
October 4, 20196 yr 14 hours ago, rw- said: I get 429W at 9:30 am up from 395 before cooling with water. May I ask how you get the water up there?
October 4, 20196 yr 19 minutes ago, Jaco de Jongh said: May I ask how you get the water up there? Good question. It's a net loss if you need more than 40W to get the water up there 🙂 I still think the most efficient off the shelf thing you can do right now is a heat pump with a collector under the PV modules. I saw one for sale some months ago. If you're going to hwat water anyway (and most households do), take the heat from a place where you don't want it 🙂
October 4, 20196 yr 1 hour ago, plonkster said: Good question. It's a net loss if you need more than 40W to get the water up there And even if its gravity feed out of a tank, you will most probably need more energy to get the required amount of water to cool the panels into the tank than what you will score out of cooling the panels. Even the cost of using municipal water to do so, might be more expensive than the wattage you score. I was thinking in these lines a few years back when i started with solar, but could never make the maths look good, so I dropped the idea.
