October 4, 20196 yr Good day all. my local supplier is requesting some values before a warranty for the Pylontech batteries can be activated. The problem is that the values relate to Voltronic inverters and I have Easysolar inverters (Victron Multiplus). Can someone please assist me in where to get the corresponding values with my Easysolar: Program 02: Max charging current Bulk charging voltage (C.V. voltage) Program 05: Battery type Floating charge voltage Program 12: Setting voltage point back to utility source Battery cut-off discharging voltage when grid is available Program 13: setting voltage point back to battery mode Battery re-discharging voltage when grid is available Program 26: Bulk charging voltage (C.V. voltage) Battery cut-off discharging voltage when grid is unavailable Program 29: Low DC cut-off voltage Can someone also tell me if I must still obtain a local warranty from my supplier even though I have filled in the Pylontech "sign up battery" section for the warranty and have received an official registration number? thank you in advance and kind regards
October 4, 20196 yr 7 minutes ago, Mr T. said: Can someone please assist me in where to get the corresponding values It's all in the settings in VE.Configure. Except for 12 and 13. Victron ESS setups don't switch on voltage. They use battery SOC. What is more, if you turn on DVCC then charging is controlled by the BMS anyway. The stuff you need to set is all explained here: https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom Don't worry about yours being a US3000. It's still the same basic battery. Send screenshots of the VE.Configure charger tab and the ESS assistant config. That should be enough.
October 4, 20196 yr Program 02: here i am actually not that sure but i suspect 30A Program 05: USE Program 12: 48V Program 13: 51V Program 26: 53.2V Program 29: 47.5V you should also set 27 somewhere between 50.3-52V note these are Axpert values, your corresponding should imo be similar? Edited October 4, 20196 yr by Dex_
October 4, 20196 yr Author Thanks for that. I will send the screenshots as suggested plonkster. all the best and kind regards,
October 4, 20196 yr Author I was actually going through the linked document already. All info is there. Thanks alot
