Posted March 27, 20205 yr Hi, I am new to the forum. I am on the search for a user manuel for a Mecer SOL-I-AX-5KP inverter, can I find same on this forum or do anyone know were I can find one, perhaps a URL?
July 21, 20222 yr hi if possiblr could anyone advise on how much batteries can be connected in parallel thanx
July 21, 20222 yr 2 hours ago, Saeed said: much batteries can be connected in parallel There isn't really a limit. When you get over about 8 Pylontech modules, then you need extra equipment (a hub?), and it becomes two or more Groups in their terminology. Over about 4 modules, you have to get creative about connecting them together so that they share the current (both charge and discharge) properly.
August 6, 20222 yr Hi I am a newbie. Kindly assist me with how to "factory reset" I have the SOL-I-AX-5KP model. Thank you
August 7, 20222 yr I believe that the supplied (or readily downloaded) monitoring software Watchpower has a factory reset option.
January 31, 20241 yr My blue tooth function is not working on my mercer SOL-I-AX-5KP. is it possible to connect to the box in another way?
February 1, 20241 yr Yes, you can use RS-232. You will need the cable that came with the inverter and a USB to RS-232 adapter.
April 20Apr 20 please help. my mercer SOL-I-AX-5KP kepps switching off the pv and on again, i suspect it dont like the voltage. After doing this a few times it stays off. i have four panels.
