March 28, 201610 yr Hi all, As part of our solar project, we replaced the fridge with a Bosch KSV36VL30, which is A++ rated. It really is an awesome device at a good price (compared to, say, the fancy Samsung and LG stuff which often costs more and use more electricity too). Tonight, while cleaning out the drain pipe, I noticed it uses an interesting arrangement at the back. Where every other fridge I've owned simply has the drain pipe running straight into a plastic container on top of the compressor (where heat from the compressor will evaporate it), this one has plastic channels running the full width of the fridge, arranged such that the water will actually dam there, and overflow into the usual container on the compressor. Now I am curious why they would do this? My best guess is that leaving the water there, right behind the heat-exchanging grid, probably helps with efficiency. I would think that perhaps it puts the water there so that heat from the grid will evaporate it, and good old physics 101 says that in order for the water to change state, it has to absorb heat from the environment, hence: More efficient heat exchange. It's a guess, but I can't think of another reason to do this. Anyone want to speculate? :-)
March 29, 201610 yr Author Drain hole doubles as vacuum release. That's how I discovered it. The fridge became harder to open over time as the hole got blocked. Sent from my GT-I9195 using Tapatalk
March 29, 201610 yr If the is water dammed in the hole air under pressure would be forced through and bubble through the water but normal airflow would be restricted.
March 29, 201610 yr I learned that also the hard way, suppose it pays to read the manuals.....every couple of months use a cotton bud to clean the "hole"
March 30, 201610 yr Author 15 hours ago, Chris Hobson said: under pressure would be forced through But it is a vacuum release... it sucks in air. You open the door, cold air falls out, warm air moves in. You close the door. Little circulation fan in the back turns on and rapidly cools the warm air. Warm air contracts and suck down the door. Vacuum release pipe ensures that the door will open again a few seconds later... not a minute like it was for us (which is why I had to clean it)!
